Broken remote cable
JoeSoap76
Scotland
Well, this is frustrating. And at £31 (including delivery) quite expensive.
Can’t think I was particularly ham-fisted with it, it just came away still attached to my iPhone when I’d finished flying this morning. :(
You could connect your Apple device to the USB port on the bottom of the remote controller via a Lightning cable.
After all the problem with that plug I have been using just to charge, using usb only.
Reactions: JoeSoap76
You can use your ipad device or phone charging cord by plugging it in below. here is a picture showing where the plug is
There was a thread a while back about the port on the side of the controller being fragile and the poster had started using something like this, with a detachable magnetic end that they just left in the port for charging:
https://www.amazon.co.uk/dp/B06XYNWPTC
I got some to try, but with the magnetic bit in the controller it was continually losing connection to the iPhone connected to the bottom port, so I went back to the side port.
Most use the magnetic ONLY for charging, not for telemetry.
Just came in amazon 2 min ago [emoji850] not suppose to know
Oh, that’s what I was doing: magnetic bit in the side port, iPhone connected through bottom port. Seemed to interfere with the connection quite badly.
you might check the cords (or it may be something else)... i know more knowledgable pilots than me that are using this setup exclusively with no issues.
Joe: I never use my DJI-provided mini cables because I use a tablet and the USB-A lower port but I wish you were in the US as I'd send you mine. I never use my iPhone any more with the M2P.
Yup... took the chance today to try again with a different cable to the iPhone and it worked. Guess the one I was using before was a little bit duff. :)
Reactions: Aerial West
Haha, yeah, sometimes its the silliest things. i hatew when i do a bunch of troubleshooting for deep, technical things, and then i just wiggle a cable and everything works. AHH!
vjsbg
