Continuous flight time
Kingpro
Cali
What’s your experience with swapping batteries and continuing flying with the mavic air? I know we get roughly 20 mins per battery but is it safe to continue flying the aircraft or will it overheat if I keep flying and swapping batteries?
A friend of mine flew his Mavic for 6 straight hours, only stopping for battery and controller changes. These motors are good for hundreds of hours of flight time whether it be in a short period of time or over a number of years.
That’s reassuring. I assume an hour is all I really need. All I can probably pull of anyway with 3 batteries in possession anyway! Thanks
Reactions: Inspirephil
Yes, it's perfectly safe to swap batteries right away and continue flying until you're done.
Reactions: Kingpro
Actually the motors would have a minimum and maximum temperature range. I’ve experienced temperature alerts while flying my previous Drone which was a Ehang when flying in the summer heat of Texas. Ambients of 98-99 F. Batteries were very hot to touch and motors where hot. Also had maximum lift reached in heat of Texas
My two cents
Reactions: Kingpro
Long time drone fan. This is my first real power drone. Love the Mavic Air so far. Definitely buying more batteries and charger. Has anyone ever had a motor failure? Is it easy to replace the motors? or other parts?
8 batteries back-to-back before controller needed charge. Several times. MPP had no complaints.
Reactions: Kingpro
I have one battery. Have two more on the way. I have burned out motors on other inferior drones. I love to fly. So I wanted to get the most out of my Air. I have read other pilots get 5-8 continuous battery changes. Just wondering what the limit might be so I don’t cause damage by burning motors or other components.
If teh drone handles 8 batteries back to back, it's not going to get any hotter if you fly 88 batteries.
DJI demonstrated flying one of their drones for 72 hrs continuously a couple of years back.
Jerry from ok
