The “C” in CPL has nothing to do with the effect changing when the filter is manually rotated.No, nothing you can change except the exposure compensation and 'lock in' the exposure (at least at the moment, hoping a firmware upgrade, above .400 will allow more manual control).
The CPL is just going to do 'its thing' on the light entering the lens. And if you have a true circular polarizer (that can rotate) then there is a polar pro video out there that talks about how to adjust on the ground before taking off. In essence they suggest that you hand hold the drone looking in the direction that you will be shooting, and rotate the CPL until you get the effect that you are looking for...then take off, shoot video and return. Of course if you don't have a pre-planned shot (or list of shots) then this method doesn't really result in a practical procedure. adjust -take off - shoot video-return to home-adjust-take off-shoot video-RTH, repeat. Not great.
But if you have a true CPL then at least you have the option to adjust the 'strength' of the polarization.
If you have a polarizer filter that does not adjust, then its essentially just meant to reduce light entering the camera and cut down on some glare/reflections. Best to try it out and see if you like the results...sometimes flying with it, sometimes leaving it in your drone bag. The extra blue in the sky can be nice...
No. The auto iris function will take care of the light lost. There are two types of polarizer...Circular (CPL) and Linear. The Linear is typically for larger format cameras and there’s not option to adjust the polarization other than rotating the filter mount, which generally is a Matt box. CPL’s are mounted in a ring that allows one to actually rotate the filter, those finding the sweet spot for maximum effect. Bear that in mind before you go airborne. Point your camera at a cloud and rotate the filters until the cloud becomes well defined. If it’s cloudless, point the camera towards the sky opposite the sun and rotate the filter until the sky becomes darker or saturated.When using a CPl filter on a mavic mini do you have to change the camera settings ?
I agree with checking the setting before flying.Too much polarization can result in a darker(?) area in the center of the shot,becoming lighter on both sides.Use a filter moderately at first,as removing the effect can be troublesome,if not impossible.Contrary to popular belief,the strongest effect is achieved at 90 deg.from the sun,not opposite(180 deg.)the sun.This link may be helpful:No. The auto iris function will take care of the light lost. There are two types of polarizer...Circular (CPL) and Linear. The Linear is typically for larger format cameras and there’s not option to adjust the polarization other than rotating the filter mount, which generally is a Matt box. CPL’s are mounted in a ring that allows one to actually rotate the filter, those finding the sweet spot for maximum effect. Bear that in mind before you go airborne. Point your camera at a cloud and rotate the filters until the cloud becomes well defined. If it’s cloudless, point the camera towards the sky opposite the sun and rotate the filter until the sky becomes darker or saturated.
Unfortunately you are harbouring a common misconception.No. The auto iris function will take care of the light lost. There are two types of polarizer...Circular (CPL) and Linear. The Linear is typically for larger format cameras and there’s not option to adjust the polarization other than rotating the filter mount, which generally is a Matt box. CPL’s are mounted in a ring that allows one to actually rotate the filter, those finding the sweet spot for maximum effect. Bear that in mind before you go airborne. Point your camera at a cloud and rotate the filters until the cloud becomes well defined. If it’s cloudless, point the camera towards the sky opposite the sun and rotate the filter until the sky becomes darker or saturated.
