Replace it. You may lose antenna function and almost certainly will have excess vibration.I accidentally dropped the bag containing my drone and Cracked my Landing Gear
Can Repairs be done or is it necessary to Replace the landing gear
Probably but its sort of heavy grade stuff, not sure how it would affect the balance of the drone. Other experts on here might fill in the blanks?Would JB Weld For plastic be any good...I’ve discontinued using the drone because of this damage
Be sure to don’t get any glue on the parts you need to remove where they contact those you’ll keep. Also don’t get glue on screws.I placed an order for replacement legs from AliExpress, but they are shipped from China and will take more than a month to arrive...In the meantime I’ll make the drone useable for flight by gluing the cracks with JB weld
Sounds like a plan let us know how you get on budI can unscrew the bottom part from the arm before applying the JB Weld..It will make it easier to apply the glue...That way it won’t get on any of the other parts or screws
