On my smart controller the direction indicator on the map views points the opposite way the drone is flying , can this be adjusted???, I am new to this it is probably a dumb question
Tap the map on your controller to bring it to full screen and then check relative map vs your orientation. If the arrow points to the actual north your good. Still I calibrated everything when I first got my bird.Is the arrow is wrong relative to the map, or is the map just oriented incorrectly relative to the direction that the controller is facing?
