DIY Signal Booster
hakaniko
İstanbul
Hello to everyone. I bought 2 signal booster from Aliexpres. I made my own booster.
My maximum distance was 2081 meters with stock antenna.
2 x 4w 2.4ghz signal booster (6-16v)
2 x 5dbi omni antenna
2 x 3400mah 18650 li-ion battery (Connected parallel - Totally 6800mah)
1 x USB Type-C 18650 1A charger board (about 4-5 hours)
1 x DC-DC Step-Up Converter (3.7-4.2v to 7v)
1 x mini voltmeter (Ordered. For cells voltage)
I have not tried yet. I will try when I add the voltmeter.
2.4 ghz will be a problem in the city but I think the range will increase out of town.
IMG_20200204_123055.jpgIMG_20200204_123102.jpgIMG_20200204_173827.jpgIMG_20200204_173840.jpgIMG_20200204_173900.jpgIMG_20200204_173958.jpgIMG_20200204_174041.jpg
hello, I think you've had enough 1 x 4w 2.4ghz signal booster (6-16v),it would be better to put a panel instead of an omni directional antenna
vanillasky
