drone powers up instantly when battery is installed
emufriedchicken
Geraldton Australia
As the title reads I have a battery that as soon as I install it into my M2Z it powers the drone up before I even touch the power button on the battery. When I do press the button on the battery all 4 status lights on my battery stay lit. Battery was manufactured 07/19 and has total of 9 recharges. Battery hasnt been dropped and no visible signs of other damage or swelling?
Reactions: Capt KO
This looks like a circuit issue inside the battery. Can you power the battery off with the button?
Reactions: Capt KO
Yes you can power the battery off with the button but the drone stays powered on till you remove the battery...I have tested my other 3 spare batteries and they are fine its just this one!
Reactions: Capt KO
For sure a short circuit in that battery. What was the purchase date of your drone? If you are within 6 months, they should warranty this one.
Reactions: Capt KO
7th of November 2019 was the purchase date...Ok will have to reach out to DJI product support and see what they can do for me.
Yes, I would definitely get it exchanged. Do not use that defective battery any longer. Good luck on the process. ;)
Reactions: emufriedchicken
Take a video of it and then send it back to DJI, if it’s still under warranty. I had similar issues with one of mine. Sent it back, got a replacement with the same fault. Send that back and got a third one. So far so good.
It’s important that you keep a video of it happening just in case their tech says they couldn’t find anything wrong. You then email your video.
Reactions: Capt KO
tflys78
