Firmware questions?!?
sergi91
Hi i am new mavic pilot and wanted to know hown to upgrade firmware for all 3 batteries and how to upgrade battery hub firmware ? Thanks Pilots!
You can either upgrade the firmware using DJI GO like this or upgrade the firmware using the DJI Assistant 2 application (you can download it here). If using the DJI Assistant 2 application, you'll see a prompt to upgrade the battery firmware (if an update is available) as soon as you connect your Mavic. You'll need to go through that process with each spare battery you own.
No firmware updates have been released for the battery charging hub.
How can you check current battery firmware on battery?
IOW, there's no way (or need) to "check current battery firmware on battery", only whether it doesn't match aircraft's.
That's not possible. DJI GO will alert you if the firmware is not up to date.
Reactions: sergi91
Slitsling69
