I’m an owner of a broken Mavic Pro, had it two years and two days ago was my first (and last) incident. I’m at the beach for the week and obviously brought the drone. I wanted to get some sunset pictures so I decided to take it out and over the water. I brought the drone up and went right out. As I was flying over the water I received a high wind advisory. Once I received the warning I immediately turned the aircraft around to return home. When trying to return home I noticed the aircraft drifting farther away. I was flying over the ocean and continued trying to get it to a safe spot to land. I decided to fly with the wind to be able to make it to land even though it would take the aircraft a greater distance away. I was intermittently losing connection towards the end of the flight. I finally got the aircraft away from the ocean and over the sand. I dropped altitude and tried to fly closer to the home point. This was an unsuccessful attempt and I decided to land it in the sand and pick up the aircraft. I landed in a safe spot in the sand and used the map to locate it. When enroute to recover the aircraft the connection was re-established. I’m not 100% sure if the aircraft tried to Return To Home on it’s own after landing. A message did pop up asking if I wanted to cancel the return to home. I did cancel it because I was unable to see anything on the camera and knew it would be unable to make it home with the wind in it’s current condition. Once I found the aircraft it was sitting closer to the ocean then where I had landed it. It was several hundred feet from where I landed it and where the flight records show. Here is the bad news, It was being hit with ocean waves. Is it possible for the aircraft to return to home on its own once it’s landed? It’s the only reasonable explanation as to why it wasn’t in the location I had landed.
As of now the drone turns on and lights up, it does not make its sound that it normally does. It is also not connecting to the controls. I’m assuming this is a goner. Is it worth sending back to see if it can be fixed?
