Flight Records
Bchbound
Bokeelia, FL
Hi,
I saved my flight records to my PC using iTunes. Now how do I use those files to see my flights on a map ?
The text files are in Chinese and I can't open the .DAT files.
Is there a separate web site or app that can use these files to see a tracking of where I flew? I have seen that others have done this and I would like to also.
Thanks
You can read the DAT flight logs with DatCon.
i found it easiest to link my dji account to my airdata account. I've enabled "Auto-sync flight records" in DJI fly and airdata automatically loads the flight logs from the dji cloud. The free airdata account has a maximum of 100 flight logs.
To clarify, that's the most recent 100 flight logs. So, it could be a good option for those who only ever need to look at recent flights (or don't fly often).
Reactions: ff22
Thanks for all the responses. How do I get from reading the data to a map with a green line showing my flight path for the whole flight?
One option -- upload your TXT flight log here. See that page for more instructions.
Reactions: sar104
Airdata.com does all that for you for free and you don't have to deal with any file transfers once it's set up. The flight paths are yellow though...
I wanna know what you were flying! Love seeing the patterns after flight and trying to work out what I was doing to get such a tangle !!!
"I wanna know what you were flying!" With all those twists, turns and about faces, a politician by the looks of it.
Hi,
Thanks
CsvView can accept both .txt and .DAT log files. CsvView has a GeoPlayer that shows the flight overlaid on the geo image.
If you want green you'll need to change the color of the flight path.
Obtain CsvView here.
CsvView Downloads
tflys78
