Fly Update Version 1.1.6
looking forward to trying it out, not available yet on my iphone though, hopefully in the next few days it will roll out
I got the 1.1.6 version on Android, but haven't flown with it yet to experience the changes. I never had DJI Fly crash so that is not an issue for me.
The battery symbol is now moved to be the leftmost symbol. It is a circle with a gray background showing green for battery remaining and red for battery used with a number in the center reflecting the percentage. Although the number can still be a little hard to read against a light background, the colored ring is very easy to see. I suppose the number will turn red at 30% so it will stand out more. It shows the time remaining beside the battery symbol. Maybe they have improved the calculation of time remaining?
There is now a Settings>Control section called "Advanced Gimbal Settings" which allows setting Pitch Speed, Pitch Smoothness, Yaw Rotation Speed and Yaw Smoothness for each of the modes (Normal, Sport and Tripod). The Smoothness options seem to smoothly introduce control movements even with jerky stick movements, obviously for better cinematic effect at the expense of instant response.
The aircraft firmware remains at 01.00.0250 and the FlySafe database at 01.00.01.18.
Finally! Let us Know the the IOS update rolls out! I’ve been having issues with the gimbal adjustment, sounds like this update will fix that for us.
I just saw a screen capture on the DJI forum showing the battery indicator. If you also tap the battery indicator the app will also show you -
Time until RTH
Time until forced landing
Time until battery runs out
Time until RTH
Reactions: Andy57824
The gimbal adjustments update is way more than I thought it would be. Tripod can now be configured to be a truly functional "Tripod" mode.
Reactions: Nonprophet
I just update the app have not tried it yet . I have to uninstall and reinstall the get the latest version .
Could someone with 1.1.6 for Android please upload the APK to APKMirror.com? Thanks!
Works well: I really like the new battery info display!
Reactions: jlatas
I have yet to see this update on my MavAir2? Any ideas why?
DJI rolls out new updates slowly over a period of a few days. If you have an Android device you can use the Apkmirror link above to manually install the new update immediately.
Tore Korsnes
