Thanks for the reply... just to clarify:Follow me follows the position of the GPS in the mobile device connected to your controller. It doesn't change altitude unless you manually change it.
Yes it will stay at same altitude that it is at when you apply the follow me mode and stay at that till you change it. You can manually change altitude while in follow me mode just by using the stick on controller up/down.Thanks for the reply... just to clarify:
I intend to use follow me mode to walk down to our river which is downhill from the take off point. I will be walking under some light tree canopy for some of the walk. The top of the canopy seems to be below or level with the take off point, am I right in assuming then that the mavic will maintain the height above the take off point?
Cheers.
