Not aware of any setting that control
SC screen vs camera. My issue …. relative to my recording photos and video on the SD card … and then being able to review/display the photos & video recorded on the SD card with a client. So recorded video shows nicely on my Feelworld monitor however the recorded photos do not … blank screen. Thanks for your response.
It's not setting for the
SC but settings for a remote monitor, such as your Feelworld. I have the same monitor and I use it with my
SC and
Mavic 2 Pro. When you connect it to your
SC, there is a choice of have the Feelworld mirror what your
SC screen is showing, or just have it show what the camera is seeing. That means the entire 7 inch monitor will be showing only the camera view, with no flying details of the drone, or battery power remaining or GPS signal etc. as is shown on the
SC screen.
That means it's a clean image of just what I'm filming. To have either view on the monito, you have to make a choice from the
SC. Therefore, I am thinking that if your monitor is ONLY showing what the camera sees, then it might be that when you view things on your
SC, the Feelworld is not having that data sent to it, though it would have what the drone camera is seeing.
If your monitor shows all the details that you see around your
SC screen, then it should be set to mirror the
SC and whatever you see on that screen, you should be able to see on your Feelworld Monitor. check your settings or let me know what your monitor shows, Camera only or what is on the
SC screen.
