gimbal motor overload
nad16
Hi everyone,
I had a minor crash with my mavic pro two weeks ago. I was getting the errors:
1.Gimbal motor overloaded. Check weather gimbal clamp is removed.
2. Gimbal is restarting. Check that gimbal rotates smoothly if restart fails again.
Everything looked fine until I saw one of the LVDS strands was torn. So i got it replaced and my camera is now working properly.
However, now I noticed that the gimbal isn't working properly. It doesn't do the proper startup procedure, and the camera keeps tilting towards the right and downwards a little. When i gently check with my fingers to see if it rotates properly, everything seems fine.
So that brought me to changing the ribbon cable. However, when i replaced it, the old one didn't seem damaged, and with the new ribbon cable it still didn't solve my problem.
Also when I want to tilt my camera in the DJI GO app, it doesn't want to move.
I've rechecked all the connections from the ribbon cable.
I've attached a video on what the gimbal does on startup. Also every 30-60 seconds the gimbal will do random movements.
hughesthis
