New member here. Briefly had a
Mini 3 Pro, which was purchased just shortly before the
Air 3 was released
mavicpilots.com
As long as you are flying as a Recreational Pilot, the Registration is really on you, not your drone specifically. As a Rec Pilot, there is no limit to the number drones that you can register under your account. If your get a Part 107 license and you use either drone in a commercial project, that drone will have to get its own registration, if your use more than one drone in the business, then each will requires its own registration…
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in Iowa, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro and the
Air 3, including the User Manuals.
After you read the Manuals, read tehm again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Learn and download DJI
Mini 3 Pro related apps, software, and manuals at the DJI Download Center
www.dji.com
Air 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
