What kind of tests did you run?I did some testing and it appears to be off.
Basically I flew the drone next to items of known height and compared them to the display reading while hovering.What kind of tests did you run?
Did you take off from the ground right next to those items?Basically I flew the drone next to items oic known height and compared them to the display reading while hovering.
In close proximity of the items from the ground. Just curious if the accuracy of the altitude setting.Did you take off from the ground right next to those items?
As @Mavflyer noted above, the altitude is always the height above the takeoff point. It's calculated using the Mavic's internal barometer, so it's only going to be an estimate. That estimate should be close though.Just curious if the accuracy of the altitude setting.
