Hello from down under
Utz2006
Australia (Queensland)
Just a quick 'Hello' 👋 from Queensland (that's in Australia 💭)
Complete newbie and wouldn't even call myself "pilot", but having enough free time now, I decided to try my hands on using a drone (Mavic Air). Intended use eventually documenting where I live and my numerous motorcycle rides.
Have a relaxing, healthy and happy new year !
Cheers, Utz
Welcome Utz, from Alice Springs
Complete newbie
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
I really appreciate this lengthy ’Hello’ and the effort to point to the most common newbie mistakes and phobias. May I call you “Top Gun” ?? 😉🤝😂
Reactions: LoudThunder
Azra
