Here's a a link for the data extracted from the .txt file. Thanks, phantomhelp.com . Ive also attached the log file.Hi there & welcome to the forum ?
The attached .kml file will not give us any info needed to do a prediction of where the Mini could have ended up ... you need to share the complete TXT log, either share it from Airdata.com or attach the log itself directly in a new post here in the thread.
Yeah I have the link and log already posted above. ThanksHere's a link to your uploaded log:
DJI Flight Log Viewer | Phantom Help
Upload and view flight logs from your DJI droneswww.phantomhelp.com
It was drifting at 5 - 6 m/s on a course of 115° at the end of the record, and extrapolating the battery level and autoland process indicates that it would have commenced autoland in another 105 seconds and taken around 80 seconds to descend to the ground, which was 60 m or so lower in that area.
On the map that translates to the area around the yellow pin:
The green circle is a 100 m crude error estimate for drift rate and course uncertainty. I'd take a look around there.
Thanks alot I'll take a look tomorrow and let you know the outcome. You wouldnt happen to have the .kml file or something i could upload to earth or maps?
