How Do I Open Flight Logs (.txt) in Litchi via a Crystalsky?
JAW
Did I Just Back Into That Tree?
Coastal NC to Long Island
The Litchi manual says "Flight logs are saved in the mobile device's internal storage in the "LitchiApp/flightlogs" folder. Android only." I can drill down in the Crystalsky to where the .txt files are but when I try to open one, it gives me a choice of programs, none of which work. The flight logs I'm looking for were done using Litchi, not Go4.
ADDED: I was never able to actually locate the "LitchiApp/flightlogs" folder but the text files I did find were the correct ones at InternalMemory\DJI\dji.go.v4\flghtrecord\*.txt
Obviously, I'm not doing it correctly. HELP!
TIA!
The Litchi log files have a CSV file extension (not TXT). When you locate them, you can upload and view them online here. Or use one of these tools.
Reactions: JAW
Thanks for the suggestions, but this is the file I am trying to open (along with 3 other flights from the same day.) that are located in my Crystalsky in the InternalMemory\DJI\dji.go.v4\flghtrecord\ folder:
DJIFlightRecord_2019-06-4_[13-43-29].txt
Those are flight logs from DJI GO. I thought you were flying with Litchi?
Definitely flying with Litchi.
I finally figured out that the built-in CS file explorer is pretty limited. I was able to hook up my CS to my PC and access ALL the CS files, both internal memory and the sd card. The files I noted above came out gibberish but the CSV files were there as you mentioned.
The key was hooking up the CS as a USB storage device on the PC.
Thanks again for the help!
tyroe1998
