- Joined
- Nov 22, 2017
- Messages
- 305
- Reactions
- 42
- Age
- 48
After 10 days, they start discharge. This is the default for the M2 Battery with no use after charging.If I charge a battery in full, what is a good approximation, for how many days it remains practically fully charged?
Anyone knows an actual self-discharge plot for M2P battery?
(Flying in places with no electricity.)
Don’t believe it is configurable anymore. Default is 10 days to begin auto discharge although you may see a 1-2% drop from 100% charge in 2-4 days if you leave your batteries fully charged.There's a setting in DJI Go, I think the max is 10 days before they auto discharge.
Not for the M2P anymore ... 10 is the only way to go.There's a setting in DJI Go, I think the max is 10 days before they auto discharge.
He did not say that, he said turning them on completely. On the Mavic 1 just pressing the button to check level would reset, but on the M2 it won't, need to fully turn on for that.What I don't understand is that checking the status of the battery by pushing the button, it resets the counter as @old man mavic pointed out.
Really, not tried it out myself but as what I read and heard, the behaviour is unchanged to your Mavic 1. Simple push resets the counter ...He did not say that, he said turning them on completely. On the Mavic 1 just pressing the button to check level would reset, but on the M2 it won't, need to fully turn on for that.
How do you discharge. Without using themI agree with OMM. If I charge any of my lipos, I use them as soon as possible, preferably the same day.
It weather interferes with my plans, I will dis-charge my batteries within a day or so.
One of the easiest ways to shorten the life of your lipos is to leave them fully charged. Or dis-charged to very low levels for that matter. I try to keep my lipos in the 50% charged range when not being used.
i made myself a simple discharger using a 55watt 12 volt fog light bulb the ones with a single heavy duty filament i use the connector from the car charger that came with my MPP as i do not charge my batts in my car,i made up a fixing to hold the bulb be careful it gets very hot when on and also fitted a on off switch to the live wire all you have to do then, is turn on the battery flip the switch and watch as the battery discharges, the current draw is pretty much in line with what the mav draws and the battery gets slightly warm during the process, with the addition of other types of connectors i am able to discharge my 3c lipos and before i sold it my phantom 3 ones as wellHow do you discharge. Without using them
Good thing is the DJI USB adapter. You can hook on 2 devices to the ports ... I have 4 batteries and sometimes I can only fly 2 or 3. The rest is fastly used with re-charging USB devices like phones, tablets, gadgets at home.How do you discharge. Without using them
I personally have a USB Digital Fan that I use to bring my batteries down to storage levels. Takes about an hour to discharge to 50%.Good thing is the DJI USB adapter. You can hook on 2 devices to the ports ... I have 4 batteries and sometimes I can only fly 2 or 3. The rest is fastly used with re-charging USB devices like phones, tablets, gadgets at home.
Amazon.com: DJI Mavic 2 Battery to Power Bank Adaptor with Luckybird USB Reader : Electronics
Buy DJI Mavic 2 Battery to Power Bank Adaptor with Luckybird USB Reader: Battery Chargers - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
You could also connect a USB lamp to it to quickly come down the storage %.
There are specific dischargers too, but they are comparably bigger and there's so far no need to waste that energy in the cells, if I can use it with other devices.
