iPad Mini 4 help
  • Thread starter Thread starter Deleted member 94307
  • Start date Start date
D
Guest
I have iPad mini 4 and have everything turned off and took all the apps I don’t use off. It has the lower memory of the two models and has internet.
Large screen often breaks up/completely freezes when I use it and sometimes I get the cpu fully loaded message from go4 and dji go app. Same thing happens with all three of my drones when I use it. It’s worse in the heat.. seams to get better when I keep it out of a case but still has trouble.
I don’t think it had this problem right away or I would have returned it. That makes me suspicious about the cause. Although I guess new versions of dji go could have started over taxing the cpu.Many people have blamed the A8? Processor in the mini 4.
I have the mini updated . Is there anything I can possibly due to make it work?
I had my M2P from just over a couple of weeks and started with my iphone 8 to discover that I needed something bigger but not too big.
I bought a second hand iPad mini 4 cellular 16gb on ebay and it has improved the way I fly the Mavic a lot.
I seriously thing that your probleam has nothing to do with the processor or anything else in the iPad because mine works just perfect with it.
The only think I can suggest is to re-load the go4 app.
Do you turn off WiFi or cellular when you fly? Anything with settings I could be doing wrong?
I also use the mini -4 . Mine works great . If I’m in a spot that has cell service I will hotspot my iPad until I load the map then I drop the hotspot . I also use the iPad in airplane mode. .
Mine is only the basic model with only wifi . It is the 128 model . I also have a old iPad that like 5 years old and it works also but it’s big and clumsy .
I don’t really know if I am doing it right but it works. I don’t have it on airplane mode, I can’t turn cellular off because I don’t use it with a SIM card and my WiFi is on. Like I said, I’m not expert but it works with flying and mapping too
I too use an iPad mini 4 Wi-Fi version and have no issues as you describe - is it possible the cable you are using is causing the issue?
Jim
Fresh Eye in the Sky
