No I started out with 75%Did you start using it w/ 100% charged?
So I guess it is best to have both at 100% chargedWhat exactly are you trying to achieve? Do you want the Remote Controller to charge your Iphone? Or do you not want the controller to charge your Iphone?
Controller batteries drain quickly as it is so wanting to charge the device that one flys with (in your case Iphone) is going to drain the remote controllers battery even faster.
That’s not true you can set it so the remote will charge your device in the appNo, the MP controller does not charge Apple devices.
The OP stated that it's a MP!Yes but as he wrote in his post he is not...
I'm a little confused by your terminology. What is the remote controller and what is the controller please? Don't remember ever hearing about two different devices, or where they would both fit into the grand scheme of things. As far as I know there is only the drone and the unit that we use to fly the drone, called the controller. The only other thing would be the viewing device, so the screen, be it a phone or tablet. What is this additional thing you are speaking of?What exactly are you trying to achieve? Do you want the Remote Controller to charge your Iphone? Or do you not want the controller to charge your Iphone?
Ahhh, okay because since you added the "Remote" controller as well as just controller, I was thinking you were suggesting there was a controller and a remote controller. Now I understand what you were trying to say, asking if he wanted the remote controller to charge, or not charge his iPhone. Thanks.They are one in the same.
