is there supposed to be glass on the camera filter ring?
JoshuaCarlton
I was just seeing how to unscrew the filer ring on the MA camera as I have the Polar Pro ND filters on the way, I noticed it was just an empty ring. Is this normal or did DJI forget my glass?
Reactions: BrAinZ
No, there is glass on mine...I didn't unscrew it though, so the glass could be permanently attached that I don't know about.
I unscrewed mine and there is no glass. I would say yours/ours is normal.
Mine has a filter on front, the actual lens is recessed
Mine has a filter too...it’s just a UV filter piece of glass but there IS glass on the ring that I removed to install an ND filter.
Mine did not have anything on it, just the ring.
Are you sure, so what your telling me is all you have is that tiny lens element below the ring that you unscrewed ?
The filter lens is just a bit smaller in diameter to the lens barrel, the first lens element is very small and recessed into the camera body.
It's definitely a fault not to have the lens filter
I’m telling you that when I unscrewed the ring to install ND filter there was no filter that came off, just a ring.
Then unfortunately you are missing the filter, but it shouldn't be a problem as you have put the ND on
Mine has no glass in the ring either, just the glass on the camera. My set of DJI ND filters arrived today, they look good quality and come in a cool plastic case that has space for 4 filters in total..
Does this filter come out when you unscrew the ring? Can you post a picture?
You can see it in the first picture I posted, I don't want to unscrew it as I don't like forcing the extremely sensitive gimbal in anyway. Learn't that lesson when the gimbal on the P4P was knocked out of alignment by screwing on and off filters
I think everyone is describing the lens wrong, the large glass element you see in Msinger's photo is the filter, the actual lens is the small lens behind this, recessed into the body. That is why I was surprised when everyone said the filter was missing
do72er
