The throttle should be without tension ... on a mode 2 radio that is left stick forward/backwards.I'm planning to get the new DJI FPV drone to finally learn to fly freestyle. Which of the sticks are required to be loose (not recentering), just the throttle stick or both?
Both you are able to disarm the spring tension. In the back of the controller, lift the rubber paddings and there should be 2 screws on each side. Twist those until you like the way the joysticks feel.I'm planning to get the new DJI FPV drone to finally learn to fly freestyle. Which of the sticks are required to be loose (not recentering), just the throttle stick or both?
You can release either oneYou only release throttle of course. The guides are pretty well made.
But you don't want to fly with an uncentering pitch stick, that's the question he asked...You can release either one
Yes, you don't want to, but is is possibleBut you don't want to fly with an uncentering pitch stick, that's the question he asked...
Make sure to get the DJI refresh for a total loss
