Went out today for a test photo flight. Next time I will test RTH + auto landing.
mavicpilots.com
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
drone-laws.com
You used the terms, "test photo flight" and "test RTH" so I'm guess you are new to droning so I give the Newbie Welcome Pasting…
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mavic 3, including the User Manual.
Learn and download DJI
Mavic 3 related apps, software, and manuals at the DJI Download Center
www.dji.com
Happy Droning…
