My Mavic air 2 quite literally few out of the sky. I did find the cached video of the last 15 seconds and I also have the "flight log?" if thats what its called. Received a motor unable to rotate error as the drone fell into the water. Any help?
My Air 2 yesterday was out over clear open air in sight and about 1,000 ft out kept loosing signalMy Mavic air 2 quite literally few out of the sky. I did find the cached video of the last 15 seconds and I also have the "flight log?" if thats what its called. Received a motor unable to rotate error as the drone fell into the water. Any help?
how do you find the flight log?Welcome to the forum, all be it under such a circumstance.
Did you manage to recover the drone, or was it too difficult ?
Post the log or link to phantomhelp (or airdata) report.
You probably already have these, but just in case section 3 here . . .
Mavic Flight Log Retrieval and Analysis Guide
With the introduction of the Mavic Mini there has been a noticeable uptick in the number of posts requesting help with lost or crashed aircraft. While there is plenty of help and advice available on this forum, and detailed guidance and options on several other websites, I thought that perhaps a...mavicpilots.com
The video (if you want to let the analytical minds and others see it) can be uploaded to YouTube or Vimeo etc, and the URL link placed directly here.
The cache video might be helpful, but probably just the flight log will do though.
Go here --> DJI Flight Log Viewer | Phantom Help (scroll down a bit there & they describe where to find the logs stored in the mobile device you flew with)how do you find the flight log?
DJI Flight Log Viewer - PhantomHelp.comGo here --> DJI Flight Log Viewer | Phantom Help (scroll down a bit there & they describe where to find the logs stored in the mobile device you flew with)
Once retrieved & uploaded to above site they provide you with a link ... come back & share that here in a new post.
Things turned bad at around 8:15.8 when the drone started to roll to the right and pitch backwards.Flight Logs
Upload and view flight logs from your DJI droneswww.phantomhelp.com
how common is it t for motors to fail? I change props every few months not because they show wear but just for preventative maintenance.Things turned bad at around 8:15.8 when the drone started to roll to the right and pitch backwards.
In less than a second it had rolled upside down and was tumbling out of the sky.
This suggests a problem with the right rear motor or prop.
Yep ... it's pretty straight forward, this was a sudden thrust loss due to either a failing prop or motor....This suggests a problem with the right rear motor or prop.
When it comes to the Air 2 I believe the mobile device DAT log is readable for us ... @flyacadia , in the same place you found the TXT log you have a folder called MCDatFlightRecords. In there you should have a DAT log which ends with FLY009.DAT. Retrieve that & attach it to a new post if you want to know if this was a failing prop or motor....sometimes it's hard to determine without the DAT log . . . many DJI drones don't allow those to be viewed by anyone but DJI staff.
Unfortunately nothing in the TXT log makes either a prop or motor failure more or less likely ... only the DAT log can possibly give us that answer.looks like a small bird strike... I was looking right at the drone and didn't see any. It was likely a swallow and I would have been able to sea a gull
Mavic 2, Mavic Air, Air 2S, Mavic Mini, M300 RTK, and FPV drones DAT files extracted from the aircraft are not supported.Unfortunately nothing in the TXT log makes either a prop or motor failure more or less likely ... only the DAT log can possibly give us that answer.
Below indication from the TXT log message stream is the only thing of value so far ... this message usually means what it says.
Try to retrieve the DAT log, then we will know more...
I have gotten my money out of the drone though. I swapped props monthly due to my high use. I almost always only over water so I am pretty carefulView attachment 146608
This (changing out props every month) could actually be the source of the problem. I don't know if there is a recommended time to prop replacement or its based on visual inspection but someone a lot smarted than I am and information about prop usage and failure could probably make some calculations regarding the chances of a prop failing over time versus an error occuring during the process of changing out props every month resulting in a failure.I have gotten my money out of the drone though. I swapped props monthly due to my high use. I almost always only over water so I am pretty carefulView attachment 146608
I have not been able to find the DAT files for the MA2.I do not have a folder called MCDatFlightRecordsYep ... it's pretty straight forward, this was a sudden thrust loss due to either a failing prop or motor.
But it most probably wasn't the right rear though ...
It's a bit difficult to exactly determine when it happens as all 4 stick commands was used there, all affecting the attitude of the craft in their own way... but it looks to be at 496,1sec into the flight where ...
-The craft suddenly, but shortly pitch down (green) even though the elevator is decreased (black dashed)
-The craft rolls (blue) over to the right side even though the aileron is decreased (green dashed)
-The craft starts to rotate CCW very much faster (purple) even though the rudder is held in a constant position.
It's very clear that the thrust loss is coming from the right side due to the roll direction. The craft also rotates CCW which suggests a thrust loss in a CW torquing corner (either front right or rear left) ... so it have to be a failing right front. This is confirmed shortly by the down pitch movement (green) where I have placed a red circle in the chart.
(Click on the chart to make it larger, values in the legend from 496,1sec where the chart marker is placed. Stick commands (dashed graphs) have value 1024 for neutral position.)
