PGYTECH Landing Gear Extensions for MAVIC MINI PGYTECH Landing Gear Extensions for MAVIC MINI: Amazon.co.uk: Sports & Outdoors
Door number 1 for me, much more stability in landing with these rather than option 3Same. Door number 3.
Without mention could affect the heat dissipation from the batteries. As the design is the one I most like.I already look at the third one. I prefere it because it fits to the body. I think that the others can affect the transmission as i think the antenas are in front legs?
like others i’m using the landing gear from PYGTECH ..no issues with transmission and i live in snow country i like the extra clearance
I am happy with the PYGTECH. Ground clearance is a big plus for me. If needed they can be removed easily. I leave mine on,, as I have repackaged by MM gear in a larger box. I have seen another post (picture) with the front gear removed to fit in a combo box.
I fly with them, a Firehouse LED, and a (decal) skin. All up (flight) weight at 275g. I have not seen the payload warning. I do not fly with prop guards. View attachment 88334
Will any of these cause the Payload Mode to activate? With the Prop Guards on it automatically comes on and can't see a way to shut it off. I am not sure what the additional weight tipping point is to activate this but wondering if these would do it.
[/QUOT
it depends what sort of make you get and the additional weight they impose on the drone,there is a slider in the app that allows you to activate the payload mode
