Mavic Mini Range (UK)?
Superbracey
UK
Morning. I'm a former Phantom 3 Pro owner and want to get back into flying. I was looking to buy another P3P (good performance, great video, good range, getting old) until I saw that the upcoming Mavic Mini can be had for the same price as a used P3P (new, shiney, warrantied, modern).
I have a budget of approx £3-450 and the reviews of the Mini seem largely favourable. I loved the range of my Phantom and can't stretch to a Mavic Pro.
What is the max. range in the UK? I've seen the following specs for the Mavic Mini:
  • Max Transmission Distance (unobstructed, free of interference)
  • Model MR1SS5
    5.8 GHz: 4000 m (FCC); 2500 m (SRRC)
    Model MR1SD25
    2.4 GHz: 2000 m (MIC/CE)
    5.8 GHz: 500 m (CE)
What is MIC?
Cheers.
MIC is the Ministry of Internal Affairs and Communications in Japan
Ah! So that's the potential range in Japan and not an option here in the UK. 500m max in the UK.
Thanks for clearing that up.
The standard model for Europe is going to be the MR1SD25
You cannot fly in FCC in Europe (or in the United Kingdom unless state regulations change ...)
I'm a bit confused. I live in the UK and ordered my MM from a camera stockist here. I have reason to believe my MM may have been shipped from the US (I seem to remember a New York stamp on the package). Sure enough the number on the controller is MR1SS5 and it does not seem I can switch from 5.8 GHz in the DJI fly app. Do I have an American model? If so what does this mean for me flying in the UK?
You'll be limited to a maximum range of 500m with a FCC model in a CE jurisdiction, as that is the range for the 5.8ghz CE settings.
The settings are enabled by the drones gps location.
If you had the CE model you could fly using 2.4ghz and theoretically get 4km, while still being able to use 5.8ghz for high interference locations.
So unfortunately you might have the worse combination for the UK
Also DJI won't directly honor the warranty on the FCC model as it is not officially sold in the UK, they don't have an internationally warranty.
You'll have to go back through the retailer and they will have to make arrangements in the country they imported it from.
I personally , would return it for a CE model which is what is normally distributed in the UK.
You can fly with the FCC Mini in EU, however it will have less range than a CE Model. There were video and tests done by someone from Italy. The YouTube video is here:
Then the same persons have used a FCC hack via Fake GPS to trick it into thinking that it's in US. I wrote about it here: Mavic Mini FCC Version Hack for Full Power in EU
Btw.. I can recall that there were some other folks in this forum asking about this previously: CE Version of Mavic Mini. Big disadvantages in UK and EU.
Thanks for your reply. I've since seen that Italian video flying the FCC version in Europe and your figures are at odds with their tests (even for the EC 2.5GHz version). Certainly I flew it further than 500m yesterday but returned after about 900 as I'm still finding my way.
My reply was flying the FCC model in the UK as stock, without the FAKE GPS work around.
For me there is less hassle just getting the CE version in the UK and Europe
Some people say they can't get Fake GPS to work, so be careful with that, I read some newer versions of the MM firmware affected it
Have a look at the comments in this video, apparently DJI has blocked the android back button.
I guess you'll have to test it, if they have this would limit you to the same firmware version and not be able to take advantage of any improvements or new functions added to later firmware versions.
Have a look at this post for more info on flying FCC in the UK
My reply was flying the FCC model as stock, without the FAKE GPS work around.
Some people say the hack does not work others say it does, so be careful with that, I read some newer versions of the MM firmware affected it
Yes I was only stating that the Italian test on the FCC (unhacked) got to 1300-1400 M in their didn't it?
You'll have to test it yourself to check the veracity of their claims for the stock FCC, you'll soon know if it stops at 500m or goes further.
I'm not sure I'd rely on a fleeting line of text in a youtube video.
DJI on their own forum have said you'll be limited to 500m flying FCC in the UK, but if you can fly further that would be great.
I guess with a CE model you have a theoretical range of 4km, so with this you'd have less risk from my perspective, that's all
After testing the "full FCC" hack works for me with latest firmware. Maybe others aren't following the correct procedure. You have to have the MM hover before switching the DJI-fly app on, to do this I found it necessary to switch off "open by default" in the app info. Similarly the app must be closed just before landing.
I haven't seen any video of a CE craft getting anywhere near 4km to be honest. Not that intend to go quite that far with my FCC version.
Just something to be aware of:
Yes I am aware. It means no American can ever take their MM on holiday to Europe? Or the rest of the world for that matter. Is that right?
The fact that the fly app can identify where it is and displays a message downgrading its 5.8GHz signal to the appropriate CE regs suggests suggests DJI have tried to comply. It really is strange they've come up with two versions of the craft though.
Not really.... this is how i see it:
You have one model that sells to the USA with its FCC approved power and another model that sells to the rest of the world on lower power.
The USA model can power down if its not in the USA while the other model is stuck on the lower power .. This means that people outside the usa with their reduced power model cant hack it to get usa power.. because its a different model and its fixed at that power.
Agreed. But as I understand it this is the first time DJI have done it this way. In the past they've made the switch just in the firmware (but with the same model).
4Gabe
