Mavic Pro Gimbal Flexible Flat PCB GImbal Ribbon Cable
kuwaitirock
what is the difference between these two flexible flat cable
1-https://www.aliexpress.com/item/DJI-Mavic-Pro-Gimbal-Flexible-Flat-PCB-GImbal-Ribbon-Cable/32795183097.html?spm=2114.13010208.99999999.264.pLtCxT
2-https://www.aliexpress.com/item/Mavic-pro-rack-soft-cable-protection-flat-flexible-wire-repairing-accessory-for-DJI-Mavic-pro-drone/32789350534.html?spm=2114.10010108.1000014.48.xWZT1g&scm=1007.13338.71800.000000000000000&pvid=22fc4a94-ce52-43a5-9576-9e39fc7aa7c1&tpp=1
I want to change the flat cable for my gimbal it's the one with the white sticker
Imgur: The most awesome images on the Internet
#1 is the gimbal ribbon cable. Per the description, #2 are cables located somewhere inside of the Mavic body.
Reactions: kuwaitirock
Dear Op, please be careful when buying a $42 gimbal ribbon cable from Alibaba. I wouldnt do it myself, nor would I buy a battery or props from there. They are all DJI copies, not OEM, and there is no guarantee it will work and it will frustrate you when you are troubleshooting a faulty gimbal.
Fstop Labs sells tested cables, and I have bought dozens from them for Phantoms and Mavs.
DJI Mavic Pro Gimbal Flexible Flat PCB Gimbal Ribbon Cable
As Msinger said, the other 3 cables in your picture are not gimbal cables, they run inside the main body to the FC ESC board.
Thanks I've canceled my Alibaba order and ordered from FS labs
customboxesnyc9
