Mavic Pro Motor Mod
Well I think Sir Lolo is right again. I do believe the additional fan has made this mod real and repeatable.
I am not an expert on the csviewer output, but this looks pretty darn good to me. Feedback is welcome on the data.
This flight was just under 45 minutes with a 7800mAh/4s+4000mAh/4s and 1750 grams.
EDIT: I suspected I fried something from previous tests, so I built a brand new mavic (#11) with all new parts for this mod to rule out any other potential unknown issues.
dronemods-2018-294.png dronemods-2018-293.png dronemods-2018-292.png dronemods-2018-291.png dronemods-2018-290.png dronemods-2018-286.png dronemods-2018-285.png
Graphs look great, especially the ESC temps. Is it nose heavy?
Could you show total motor power? From roughly calculating it seems like around 6.5g/W?
Remember I am a csviewer noob. I don't see anything labeled total motor power, can you throw a dog a bone here??
Yes it is nose heavy. Need to figure out a new attachment method.
Here is Mavic11 in all her newly minted glory!
I am thinking this mod might actually work... knock on wood :)
BTW - the second knock off battery controller is the one to get (the LEDs are triangles instead of circles and there are stripes along the topside). This one has no special startup procedure like all the others. If you are going to do this battery controller mod get this one and not any of the others.
1) connect battery case to the bird.
2) connect the balance cable to your battery.
3) connect the battery power to the birds external power connector.
4) DONE (controller auto powers on).
All the other controllers have convoluted startup procedures, this one rocks.
Reactions: lolo780
@BudWalker i am new to your software this week and all I can say is a giant thank you for contributing this to the community. It is evident that you put a lot of time and effort producing this product and it is awesome. Thanks again.
I have tweaked the rotor arm design many times. This is the final version that is perfect.
In the beginning I hesitated to make the arms too strong (to save weight). But with 2 kilos strapped to the bird, I don't think anything less would hold up.
If you do try this mod, discard all the previous 3d print files and use this one:
I think we might have a winner. Numbers went up as to be expected, but last time I did this same weight test without the second fan, crashed and burned around 10 minutes.
I limited this flight to 10 minutes to get the following data readings. AUW was 2.1 kilos.
EDIT: all four motors were noticeably hotter, but I could touch and hold them still.
dronemods-2018-304.png dronemods-2018-303.png dronemods-2018-302.png dronemods-2018-301.png dronemods-2018-300.png
View attachment 39996 View attachment 39997 View attachment 39998 View attachment 39999 View attachment 40000
I estimate 310w avg to hover and that’s 6.8g per w. I still don’t know what to compare this against. Do you have any examples of good versus bad??
If you compare watt hours of battery capacity to g/W, at a certain point you'll be at the top of the flight time curve where adding more battery past that will lose flight time due to reduced power system efficiency.
If your hover wattage is up 30%, how many % did you add in battery capacity.
Also worth noting that as you reduce the C draw on your batteries the effective useable power goes up.
Can have a copy of that data file?
MsH277
