Hi to all... as many others, I'm here to seek help regarding my Mavic Pro
Problem? CRAFT TOOK-OFF THE GROUND WHILE IDLING WITHOUT ANY GIVEN COMMAND AND CRASHED (INTENTION WAS TO DISCHARGE THE BATTERY - NOT TO FLY AT ALL)
Was unit in a crash? YES (BROKEN CAMERA WITH GIMBAL, BROKEN PROPS, DAMAGED PLASTIC HOUSING)
What have you tried so far? DOWNLOADED *.DAT FILES AND BLACK BOX DATA TO PC, HOWEVER THERE SEEMS TO BE MISSING SOME FLIGHT RECORDS.
I TRIED TO UNDERSTAND THE DATA, HOWEVER UNSUCCESSFUL.
What device are you using ( iphone , ipad, Samsung , etc)? AT THE TIME OF THE CRASH - ONLY CONTROLLER, NO SMARTPHONE ATTACHED.
What firmware are you running ( aircraft, remote controller)? AC & REMOTE - 01.04.0300
What Go app version are you using? 4.2.6
Any modification? (if so what) NO
Did you change anything or install any apps? (if so what) NO
Do you have a video or pictures of the problem? (if so post link) NO
Sequence of events (ambient: INDOORS):
ANY IDEAS HOW TO PROCEED???
THANKS IN ADVANCE!
- unfold the craft, removed gimbal clamp and camera cover
- placed the craft on the floor (PROPELLERS ATTACHED)
- unfolded antennas on the controller and switched on the controller (SMARTPHONE with DJI GO App NOT CONNECTED - ONLY CONTROLLER IN USE)
- switched on the craft
- controller and craft got connected
- started the motors by pushing the control sticks down and outwards
- motors started - craft idling on the floor
- I put the remote controller on the floor - few steps from the craft
- after idling on the floor for 10-15 sec craft performed ABRUPT take-off without given command (the controller was not in my hands)
- by taking-off, the craft hit the sealing and than fell to floor.
THANKS IN ADVANCE!
