Decided to practice with the CineSticks (scottymakesstuff) this morning. First problem I ran into when turning on the controller it wanted me to calibrate the sticks. I am guessing because I had them turn up pretty tight for slow action they were not centered causing the steady peep to calibrate. Once I back off the sticks and turned the controller back on it was fine. I then was able to adjust them to where I wanted them. A few practice passes in the back yard and they seemed setup fine. So off to the river to see how much they improved my twitchy stick maneuver. Controller set to cine mode and I had a nice slow and smooth flight. The return home I switched to sport mode and even with the sticks setup for slow speed it motored home just fine at a good speed.
Shot in D-Log and a LUT added (DLog-M+to+Rec709.cube)
