- Joined
- Oct 26, 2016
- Messages
- 926
- Reactions
- 706
I had a few..Stopping and starting in low light, altitude changes on it's own and severe altitude readings. I've done about 5 flights since Firmware released and all issues seem to be gone.
New firmware is out?I had a few..Stopping and starting in low light, altitude changes on it's own and severe altitude readings. I've done about 5 flights since Firmware released and all issues seem to be gone.
So your not seeing the weeble wobble effect in your master shots videos.I had a few..Stopping and starting in low light, altitude changes on it's own and severe altitude readings. I've done about 5 flights since Firmware released and all issues seem to be gone.
So it fixed the altitude errors?I had a few..Stopping and starting in low light, altitude changes on it's own and severe altitude readings. I've done about 5 flights since Firmware released and all issues seem to be gone.
Although I do not use Master Shots, I did notice that in trying it out, that the wobble issue started immediately.So your not seeing the weeble wobble effect in your master shots videos.
Phantomrain.org
Gear to fly your Mavic 3 in the Rain. Land on the water.
I find the low light performance not what it should be at all for a 4/3rds sensor. Something isn’t right there. It’s so bad I doubt firmware will fix that, bad camera design I suspect.I did some low-light flying with the Mavic 3 Cine and it seems to doing better on this newer firmware. I think they can improve it even more but the big concerns (moving on its own, lots of twitching) seem to be better.
What aperture are you hoping for?The bad low light performance is due to the fact they put this sensor on a foldable compact drone. The camera is way too small, too compact. This sensor would work better on a Phantom where the camera can be much bigger. That M3 camera needs to be twice that size, lager lens larger aperture.
Example please?I find the low light performance not what it should be at all for a 4/3rds sensor. Something isn’t right there. It’s so bad I doubt firmware will fix that, bad camera design I suspect.
Not so sure about thatThe bad low light performance is due to the fact they put this sensor on a foldable compact drone. The camera is way too small, too compact. This sensor would work better on a Phantom where the camera can be much bigger. That M3 camera needs to be twice that size, lager lens larger aperture.
It’s low light performance is pretty bad, that’s all I know for sure. I’ve had 2 4/3rds cameras and they perform way better, but they weren’t miniature compact cameras either with tiny point and shoot lenses. I expected more from that sensor in low light, it’s just not there.Not so sure about that
Can you post an example to show what you mean?It’s low light performance is pretty bad, that’s all I know for sure. I’ve had 2 4/3rds cameras and they perform way better, but they weren’t miniature compact cameras either with tiny point and shoot lenses. I expected more from that sensor in low light, it’s just not there.
You won't get any. This guy has rapidly turned in to one of those endless sources of misinformation. In this case, he apparently doesn't understand that only the aperture value determines illuminance for a given sensor size. His knowledge of optics, as with most other topics he writes about, appears to be minimal.Example please?
I don't know,there are a lot of happy M3 owners that love the low light capabilities.It’s low light performance is pretty bad, that’s all I know for sure. I’ve had 2 4/3rds cameras and they perform way better, but they weren’t miniature compact cameras either with tiny point and shoot lenses. I expected more from that sensor in low light, it’s just not there.
I've never used Master Shots. I will give it a try.So your not seeing the weeble wobble effect in your master shots videos.
Phantomrain.org
