- Joined
- Jul 3, 2019
- Messages
- 1
- Reactions
- 0
I am sorrybif I missed the thread, but do we now need to mark the FAA registration number on the outside where it is visible? I marked each battery with a label and clear tape. Will that be fine?
The FAA does not have a list of approved marking locations. The requirement is for "the registration number marking [to] be readily accessible and maintained in a condition that is readable and legible upon close visual inspection". See more details here:I marked each battery with a label and clear tape. Will that be fine?
That is the old rule and is no longer allowed. See the new rule I linked above.The FAA says you have to place it in an area that can be accessed without the use of tools so I guess the old inside the battery compartment is good for the Mavics.
I just finished the Part 107 Small Unmanned Aircraft Systems (Small Uas) Initial course, course number ALC-451. In the prep portion for the test, it stated you could place it in a compartment so long as it's accessible without tools. I'll go back and see if I can find it.That is the old rule and is no longer allowed. See the new rule I linked above.
FAA rules are often vague, but that's what I'm reading too.Although not specifically stated in the regulation, I would go further and say that it should be on the body of the drone itself and not on the battery
The intent of the new marking requirement is for a first responder to be able to approach a drone and identify it without having to pick it up. I think having the number on the prop meets the intent and the requirement.
SF
The battery would not be considered as an external surface of the SUA. It would be classed as “Fuel” or power sourceAs already stated above, the current ruling is that it cannot be hidden in an inside compartment.
Although not specifically stated in the regulation, I would go further and say that it should be on the body of the drone itself and not on the battery. I say that because:
(b) The unique identifier must be affixed to the small unmanned aircraft by any means necessary to ensure that it will remain affixed for the duration of each operation.
Batteries do and have come loose either in flight or during an impact. If the battery comes loose then the identifier will not remain affixed for the duration of the operation.
(c) The unique identifier must be legibly displayed on an external surface of the small unmanned aircraft.
This one is iffy. Is the battery considered an external surface of the SUA? Yes I guess it can be considered as such. It could also be considered a removable part and not integral, and as such not really an external surface of the SUA itself.
Regulations aside, I always put the identifier (and my phone number) on the drone body itself. If something happens and the battery is separated from the drone, I want someone to be able to find it and be able to contact me.
I dunno sounds like a thumbs up to me.FAA rules are often vague, but that's what I'm reading too.
There was another related thread a while back where someone (a few people actually) thought it was a brilliant idea to mark the number on the props. So, I emailed [email protected] to see what the FAA thought about that. Here's how they responded:
The fact that "SF" answered the question by stating he/she "thinks" doesn't give me much confidence in the reply.
Says who?The battery would not be considered as an external surface of the SUA. It would be classed as “Fuel” or power source
To me, it sounds like I only have the thumbs up from "SF" (whoever that is). I'd rather follow the official FAA rules as they are meant to be followed.I dunno sounds like a thumbs up to me.
I’m not really trying to argue I get your point but the rule say...To me, it sounds like I only have the thumbs up from "SF" (whoever that is). I'd rather follow the official FAA rules as they are meant to be followed.
I'm not sure a removable aircraft accessory should be considered the aircraft. Even if it is, the rule also states the following:Would a prop not be an external surface by anyone’s definition?
As you can see, this authorized FAA official did not seem to be sure his/her answer was correct or was giving his/her personal opinion. I wasn't looking for what someone "thinks" is the answer. I wanted to know exactly what the rule was stating.A FAA official authorized to speak on behalf of the administration who specifically answers questions from UAV pilots regarding clarification of rules regarding UAV regulations has also confirmed that, it in her view, it meets not only the language of the rule but also the intent of the rule.
An answer from someone who is knowledgeable. The person who emailed me was clearly not qualified to answer this rather easy question.What more are you looking for?
Someone who "thinks" they have the answer is not giving an answer that was reached decisively and with authority. So, no, it's not a definitive answer at all. Furthermore, since there is no guarantee the prop will remain attached to the aircraft, the FAA should probably never be recommending it as an okay location to affix the number (since that would be in violation of their rule).it seems you have provided us with a definitive answer to this question
No worries. I'm not arguing either -- just sharing my point of viewI’m not really trying to argue I get your point but the rule say...
Again just friendly debate here but if a drone loses a prop or a battery inflight then this leads to no other result then a crash at which point there is no part of the aircraft that would meet your criteria.I'm not sure a removable aircraft accessory should be considered the aircraft. Even if it is, the rule also states the following:
"The unique identifier must be affixed to the small unmanned aircraft by any means necessary to ensure that it will remain affixed for the duration of each operation"
Since the props (and battery) can become detached mid-flight, one could not ensure the number will remain affixed if attaching it to an accessory that is commonly lost mid-flight.
It’s not an accessory it’s a vital part of the aircraft and is required for flight. You wouldn’t characterize a prop driven planes prop as an accessory correct? They are also removable and replaceable no?I'm not sure a removable aircraft accessory should be considered the aircraft. Even if it is, the rule also states the following:
If someone from the FAA replying to an email that was sent to [email protected]v is not qualified to answer questions about UAS regulations there is nobody who meets that criteria.As you can see, this authorized FAA official did not seem to be sure his/her answer was correct or was giving his/her personal opinion. I wasn't looking for what someone "thinks" is the answer. I wanted to know exactly what the rule was stating.
The battery and props are two of the most commonly lost drone accessories. I didn't mean most people lose them.I’m not sure what kind of flying you do but I could not characterize “losing a battery or prop” as common. This is usually the last flight of that particular drone.
It could. But, those parts of the aircraft are rarely lost. And they are actually part of the aircraft since they are attached in a way that is not meant to be removed.It could lose a leg, a gimbal, a top cover etc
So, you're saying the FAA has no employees that probably shouldn't be working there? I'm sure you can find such employees at any companyIf someone from the FAA replying to an email that was sent to [email protected]v is not qualified to answer questions about UAS regulations there is nobody who meets that criteria.
Yes, sir. If you're explaining the law to someone and you work for the company that created the law, you should never (ever) be using the word "think" in a response. "I don't know" or "I'll find someone who knows and get back to you" would be a perfectly acceptable answer though.All this from one word?
Unfortunately, they haven't answered the question at all. They've only allowed someone to provide a confusing response. If the answer was clear, you and I wouldn't be discussing our opposing viewpoints.You’ve done us a great favor by asking the highest authority we could ever hope to answer this question and they have!
