New firmware: V01.03.0600
Wish they would forget about upgrades and new products and release the goggles that were announced seven months ago. Hard to fly looking at a phone screen after flying for years with goggles. I really don't want to buy NVidia shield just to connect my fat shark goggles. Beware the updates turn off multi flight modes and sport mode will not work until you turn it back on in the app. I think updates should leave our settings alone. This mavic is pretty sweet though!
I have downgraded the Mavic to 400 but the remote will not . does anyone know if this will be a problem
Mine failed 3 times, first time its happened to me, i swapped to a different USB port it was fine after that strangely enough.
I just did 2 Mavic's using the DJI Assistant 2. What I found is that you need to first plug in you cable to your computer and the drone or controller then turn on the drone or controller. Then start Assistant 2. It will take a few seconds then will show the icon for either the Mavic or the Controller, click the icon and then your current firmware versions will show up select the top one or the one you want and start the install. Do the same for the controller. I have found that you need to turn everything and close out the app before doing another up date that goes for your controller.
It seems to fail if you start things different mainly the DJI Assistant 2 app.
Hope this helps.
Reactions: Evans12
No, had to stop it as in work now, going to try again when I get home, try a few different USB cables, if that don't work then I might do it through the DJI assistant on the computer...bloody annoying!
I find the that the DJI Assistant work better for me, even with my Phantom 4.
Do each meaning drone and controller separately. Also plugin cables turn on drone or controller first then start the Assistant. Do not start Assistant first.
Hope this helps...
If all this backwards and update fail, I will do factory reset then update, before I send my mavic back, thank you
Also, I found that you need to plug in, start the Mavic then start Assistant 2. I have even re-booted my computer first. I have found if you have Assistant running then plug in things do not work right. Wish you luck...
Reactions: Evans12
I have done a number of updates now and have never had a problem. I always start Assistant 2 first, then connect the Mavic or RC. I always use the cable that came with the Mavic and always connect it direct to a usb port on the computer, never through a hub.
Anyone else experiencing extreme drifting (10 foot before I corrected it) and altitude loss (slowly descends until it lands) when hovering? It used to be rock solid. I have tried re-calibrating the IMU and compass and also refreshing the firmware in the assistant app.
I tried flying tonight, was pretty dark out. When I took off it did not hover around 4 feet, it just kept on going up. I pulled down on the stick but then it just wanted to go back up. This continued to happen, also was not very stable, moved around a lot. Will try again in the morning. Maybe with no light it could not figure out where it was??
No, mines as rock steady as always but can I suggest you check the control stick calibration on your hand controller. If it's out it can actually be commanding your craft to move even if your not touching the sticks
Thanks will try that. I have not calibrated anything very much always has been real stable, but I guess now is the time..
I'm done. after trying everything, only to have DJI tell me to send in the mavic for further research, and telling me it must be a problem with my computer board in the mavic, i'm staying at .0550. I missed a beautiful day of flying because of this crap.
I think I was able to finally convince the tech I talked to that I wasn't the only person having this issue, especially after he told me to wait until the next firmware release. I think they know there is a problem.
Same for me. Something is strange on 600. I can not upgrade....
TO ALL:
Do you also have on the device manager under "Other devices" an "unknwon" device?
>You see this item only if you click hidden devices on the "view-menu" item.
Maybe all peoples who have problems to update does have such a device. I have already received a few new drivers from dji but none helps....
This device is only active (Yellow exclatation mark) a short time during booting up the RC or AC, after that it is hidden and "Disconnected"
The same "unknown device" appears
Port_#0001.Hub_#0003
Currently, this hardware device is not connected to the computer. (Code 45)
Device Instance path: USB\VID_1AB7&PID_2100\6&D297EF0&0&1
Parent Device: USB\VID_2109&PID_2812\5&16bdd27b&0&1
Hardware Ids:
USB\VID_1AB7&PID_2100&REV_0100
Andy
Hello to All,
Since the latest update (0600), I am not able to succeed in the Gimbal auto-calibration process...
The gimbal autocalibration process fail after 68% (???).
Before this update (<=0550) the gimbal auto-calibration worked properly...
Does someone have this kind of problem ?
Look the screen copy (attached) of my Ipad mini 4 which shows the gimbal calibration failure.
Thanks for your help...
Sincerely
Hello to All,
New attempt about the gimbal auto-calibration :
  1. reset to factory default with the latest firmware 0060 with DJI Assistant 2
  2. calibrating compass with DJI GO 4 : OK :)
  3. calibrating IMU with DJI GO 4 : OK :)
  4. gimbal au-calibration sill FAIL at 68%... :(
  5. Tested the MAVIC Pro in flight : NO PROBLEM all works well, all features are OK Thumbswayup ;)
I suspect that this ONLY the auto-calibration process with DJI GO 4 (ios) which is buggy :D...
Sincerely
Reactions: Gray_seagull
SomeView attachment 10386 times, and this is my belief, they bring out new firmware, not to improve the existing one, but to correct some big mess in the previous version. Specially in this case when there's less than a week between them..:oops:. One thing is clear, I will update mine ASAP just in case; I flew my MV just an hour ago, to find that there was a lot of interference, new to me on a well known area; so bad I had to abort my mission without delay..
BR,
Spanish Flyer
PS. was trying to take photos of a roman bridge at the proper height, but had to take a couple much higher than planned.
Beautiful picture!
I don't know if it might help.
I've experienced some problems during update app always asking confirmation for download and not advancing at all; exited app, turned off phone/MP/router......nothing worked. Finally i stopped using my macbook while trying to update.......and the download went straight till the end with no issues at all and in 15min it was done. Looks like there was some interference between mac and iphone and the GP app doesen't like instable connections.
Warning:
Ever since I updated, my manual camera settings reset to default when I switch camera modes video/picture.
Example. Say I set my ISO, shutter for a picture, then switch it to video for a moment, the settings all go back to default. When I return to the picture mode same deal. Doesn't remember my settings.
Is this a new problem or a known one?
I wonder if the gimbal startup sequence is now going through a larger range of motion than it did previously. I had mine do a Gimbal Auto Callibration from the gimbal settings menu, and noticed that the calibration routine is different than it was with a new slow left-right panning pass. So it's possible that the startup sequence has changed as well.
I'm using the Taco ND filters and have not had it cause an obstruction yet.
To add to this: if I leave the mavic landed and turn the left stick (Mode 2) to the left and right the camera actually turns a bit on the side I move the stick. Just a little, likely less than 10°, but this makes me guess: will the Mavic camera be able to be controlled sideways also? Big YUMMM!
This is not new.
It's a setting you can turn on and off.
It makes for smoother turns when flying.
It's been there as long as I've owned the Mavic.
mariovaleo
