New firmware: V01.03.0600
To add to this: if I leave the mavic landed and turn the left stick (Mode 2) to the left and right the camera actually turns a bit on the side I move the stick. Just a little, likely less than 10°, but this makes me guess: will the Mavic camera be able to be controlled sideways also? Big YUMMM!
No. It's because pan synchronous follow is set to On. If you turn this option off the gimbal won't turn on yaw stick when the craft is on the ground and also won't "compensate" in flight.
Has anyone been able to confirm/replicate this NFZ LIMIT issue that is plaguing this firmware. Seems like you cannot take off if you have a weak gps signal? People have reported that they were unable to fly indoors..Im hesitant to update if this bug exists for sure.
Yes, it happened to me, but once you have had full GPS signal it does'nt show up again. Also my update was trouble free (Assistant 2 / PC/ Mavic and remote updated one by one.)
Finally updated to .600 and got some time to take it for testing. Everything went well (I can't have follow me mode working, tho, always the weak gps error popping), no drifting, no gimbal issues. I was flying with strong winds and I was amazed how well it did while hovering, you can't spot any drifting at all. However when I tried to test the new fixed wing mode I wan't able to activate it. The C1 appears after I move it forward for some speed, but as soon as I release the right joystick it stops hovering. Pressing the C1 doesn't do anything. Anyone experiencing the same problem?
Thx in advance!
Thx in advance!
I think, sure someone can confirm, to enter fixed wing you have to press C1 and forward stick at the same time.
Reactions: D700
I guess you configured the C1 button to enter fixed wing when pressed, right?
Reactions: D700
Yes, and C2 to exit
thx for helping, Ryo
No prob mate, sorry i can't tell any more because i tested fixed wing only once and even not sure if i was really doing it. :D
Reactions: D700
Many thanks, sir :)
Reactions: Gray_seagull
I didn't have any problems with the upgrade to .600 but after installing it and taking it out for a test drive I noticed quite a bit of drifting when hovering. I just came back from vacation in Florida and did a lot of flying down there with no drifting using .550. I'm switching back to .550 as I'm typing this.
I just did the update everything seemed okay, however on start up with the gimbal some reason I got some huge tilt issue and started to straighten up slowly, has anyone else has this issue with the new update gimbal acting funny
I'm experiencing the same exact symptoms with my gimbal after upgrading to .600. The gimbal is good most times, but then I get this strange tilt (about 45 degrees) sometimes. I have to reset the bird to get it right. Prior to the upgrade, this bird had zero issues.
Reactions: Antohagg
I've only done one full flight since upgrading to .0600 and I calibrated my gimbal and compass before taking off. I wanted to see the new longer gimbal calibration process (sure enough, it's just as people are saying, takes a while, does a lot more). After that worked, I flew indoors a little, then outdoors, then up at 400' in sport mode where there was quite a wind blowing - all ok, no gimbal issues at all. So far I'm completely happy with .0600.
Yeah it's odd, I don't know if it's part of the the startup gimbal process now??? I did do a gimbal calibration and that was a much longer process and it said calibrated complete and looked good, so Not sure if it just from the update. However when i started flying everything seems fine and worked well.
I just did the long gimbal calibration and it seemed to work fine too. So we'll see how it works tomorrow. Going to shoot some lakes at sunrise tomorrow morning.
Thx in advance!
Mine worked well except flying towards the sun...It would stop and hover. Were you towards the sun?
Reactions: D700
For the record - my upgrade to 600 went perfectly fine, I flew for an hour today, first I got excited that my Nexus 6p 7.1.2 is finally usable, then the app once again died while was on my second battery so I went back to my S4 and that worked perfectly fine. No issues with NFZ, tracking etc.
So it's not all doom and gloom.
Anyone else experienced massive video lag after 4.0.7 + 600 upgrade on IOS? Just did a first flight today; experienced video transmission lag already at 60 meters distance; never happened that with any previous firmware versions. I'm starting to get totally annoyed about DJI's firmware updates...My Mavic was a very good piece of technology; why do they keep ruining things that went so well?
mariovaleo
