New here, intermediate level operator looking for knowledge. Thanks, y’all!
I have several drones, but fly my Mini 3 Pro quite a bit. I just bought the Mavic 3 Pro.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Mini 3 Pro Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone. However the other drones may need to be registered if over 250 grams…
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Hello from the Crossroads of America DjiDan4.
Welcome to the Forum. :cool:
Welcome to the forum! :)
WELCOME to the forum from your NC Neighbor (up in the Smoky Mountains of NC).
paul44509
