on this linkDJI underline-bold that:New Smart Controller Firmware Released (2019/04/25)
Overview: Date: 2019.04.25Smart Controller Firmware: v01.00.0530DJI GO 4 App: v4.3.16DJI Pilot App: v1.3.0DJI Assistant 2: DJI Assistant 2 For Mavic v2.0.8 What’s New? Added Aircraft Management under settings. Once connected to the Smart Controller, an aircraft can be added and managed in...forum.dji.com
Notes:
- This firmware version contains important updates, and the Smart Controller can only be updated to this firmware version via DJI ***istant 2. Download the latest DJI Assistant 2, and follow the steps in the System Update section in the DJI Smart Controller User Manual. Download DJI Assistant 2 at Mavic 2 - Specifications, FAQs, Videos, Tutorials, Manuals - DJI.
- Contact DJI Support if the update fails several times.
I finally got the DJI Assistant software to recognize my SC by logging out - logging in - waiting - waiting AND THEN! the SC mounted on the screen and I could choose to upgrade.
AND IT DID
Next time Maybe DJI could push out a notification to the SC that it requires to be updated through the Assistant? Maybe?
Godtfrank
If you have a sd card in controller remove it per dji support having same problem as we text stuck at 1% tried for hours last night on assistant 2 talked to dji tech support told me to remove sd card then tried again still stuck at 1% talked to support again he asked if I was using windows 10 said I need to use 7 or 8 so thats where I am but using a friends laptop gonna try and down grade to 7 or 8 and try again not sure about macAnd my update went wrong!!! The SC found the new update and started to download. After complete download the device ask me to confirm the installation. I did and then..... nothing happens. It stays on "Updating 0 %" for over an hour. Every time I turn power off and on, the SC tells me that a new firmware is ready to be installed (V01.00.0530) and when I press OK: It stays on "Updating 0 %".
After some google'ing I found that DJI write that the correct way of updating, is to do it via DJI Assistant 2 for Mavic.
I have now tried but my SC don't connect to DJI Assistant 2 (just updated to the new 2.0.8 and restarted my Mac).
Does anyone know how to remove the downloaded update file on the Smart Controller so I can try to download a new one?
Or any other suggestions?
Greetings from Denmark
Godtfrank
Yup. Mine won't update either. Exactly the same symptoms.
I've tried using both Wi-Fi and DJI Assistant 2 v2.08. Tried it both with and without the SD card installed. Nothing works.
- Won't connect to the latest DJI Assistant 2 v2.08.
- Controller just sits there with "Updating (0%)" on the screen.
John in Texas
Hi DronCific.If you have a sd card in controller remove it per dji support having same problem as we text stuck at 1% tried for hours last night on assistant 2 talked to dji tech support told me to remove sd card then tried again still stuck at 1% talked to support again he asked if I was using windows 10 said I need to use 7 or 8 so thats where I am but using a friends laptop gonna try and down grade to 7 or 8 and try again not sure about mac
