Hi, does anyone here did plasti dip on your Mavic Air 2 or any other previous drone before? any bad effect ?
Yes, liquid rubber can spray, would like to cover the entire of the mavic air 2 body, expect for those sensors and the motors
Yes, it would. ??What happens when you have a warranty issue? Would this not void any warranty?
Hi is there a size limit for your operator id (how small you can have itYes, it would. ??
DJI have said anything added to the drone can void a warranty. It’s a bad idea in my opinion. Just add a skin, at least that’s easy to remove if you have a warranty issue.
Text must be Block capitals, no smaller than 3mmHi is there a size limit for your operator id (how small you can have it
Not only would cause overheating, it would cause problems with transmission signal. RC and GPSYes, it would. [emoji106][emoji106]
it would probably cause the drone to over heat too. DJI design Mavics with air flow as part of the temperature control for the CPU etc.
Plasti dip is a type of liquid rubber that consist no metal elements, which means that it won't interfere with the aircraft signal, plasti dip can be peel off as well.
