Premier 15 Project settings
FLaP
First time editing Mavic 4K video with Adobe Premier 15 and wondering if someone can recommend the correct Premier Project settings. Looking through the options I don't see a setting that matches the resolution and frame rate of my original video.
You may not need to set anything, in Premiere Pro you can just drag an imported file to timeline and it matches the settings.
Or create a new Project from clip if you right click it.
Basically at editing stage you want to be matching original file even if you have to enter or change some details manually.
Thanks for the response. When I drag a clip over I get a yellow line above the clip indicating the project standard has not been automatically set. I will try your suggestion and manually edit the project standard to the resolution of the clips. Thanks again.
BuzoLibre
