I've bought, sold and repaired a good number of drones, and one consistent thing I have found is that the DJI props are well balanced from the factory. I have also not found a single example of a new prop from DJI that was defective at the prop blade, prop hub, bent prop, or prop that is too loose at the hub. I have honestly been through thousands of them. DJI is really on top of their game when it comes to prop QC going all the way back to the Phantom days.
Getting back to the point of this thread, an experienced owner should almost never have to balance his/her blades, and a newbie should never try it. If a blade becomes unbalanced, it's usually because of a chip, crack, or damaged rivet. In that case a quick visit to any DJI online dealer will remedy that for $10 a pair.
Back in the heli days, yes you had to balance and track the blades, but these days, DJI does the work for you.
I will mention one more thing that has become abundantly clear to me. Using generic props can be a recipe for disaster. Those can arrive out of the box out of balance, loose, wrong pitch and a plethora of other problems that will just ruin your day. I stick with OEM DJI props that were designed for the drone Im flying. If it ain't broke, don't fix it.
