Red green function
ovidiustefan
Hello!
I have a problem with my Mavic Air. After flying it for a while battery went low so I decided to land it and download the pics to my phone. Meanwhile the battery died and after a while each rotor started to rotate individually for a bit, but fast enough to make the drone jump around. I stopped it because I didn’t know what was hapoening, I replaced the battery and now, after I turn it on, there is no beep, front lights are off and function button has red-green light. What should I do to get it working again?
Thank you!
Hello!
Thank you!
make sure everything is charged and restarted and connected, if there is still an issue check the manual:
check the aircraft status light
check the battery status light
I have tried to restart it. The drone doesn’t beep when it starts anymore and the front leds don’t light up. And the function button isn’t alternate r/g it’s at the same time. Is it a combination of buttons to hard reset it? The computer app doesn’t see the drone either
I was thinking the same, but I was hoping for a fix I can do myself since I just got it last week. Now I am not sure how to proceed, because I bought it in Tokyo and I live in Singapore. Closest DJI repair, from what I checked would be in Hong Kong... Any advice on that? Thanks
customboxesnyc9
