Sensors
Duane
Should it be possible to disable sensors AFTER getting a low battery warning? I was unable to do so but had no problem earlier, before a low battery warning.
Reactions: Former Member
You should be able to disable the sensors anytime mid-flight.
What seemed to prevent you from disabling them?
The slider on the controller would not disable the sensors. After changing the battery, it again worked fine (without a low battery earning).
iamkjf
