I have a MA2, running DJI Fly on iPhoneX together with the controller.
When setting/changing the Homepoint, one can choose to use the drone’s actual position or the controller’s position. This is useful when you move away from the starting point.
To me, it seems that when using the drone’s actual position, the homepoint is set more accurate than when using the controller’s position. When using the latter choise, I presume the GPS position is delivered from the iPhone and then forwarded to the drone.
Anyone having the same experience?
