Received my DJI
mini2 as Christmas gift from my son. Have only flown 3 or 4 test flights so far. Will have to wait a while for more as my battery compartment door came off while I was trying to remove a battery.
OK, Sky, here is your Biggo Welcome Note…
I am sorry to hear you broke your new toy, Here is how I remove the battery in my
Mini 2. You can also read the entire thread for other ideas…
In searching threads I only found one related to battery removal, but no solution on easy removal from drone. Has anyone come up with a reasonable answere? My fingers hurt pushing the tab and trying to remove the battery at the same time. HELP!!
mavicpilots.com
Any case back on point… Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot. I have now passed my Part 107 License Exam and am awaiting the arrival of my Permanent License and then I will re-register my
Mini 2 under Part 107.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in the Virginia/North Carolina area, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy Droning…
