All those who still regularly use the Mavic 2 series, do you suffer with regular video feed and control signal dropouts while using the 2.4ghz transmission frequency? Even when the distance between the drone and the controller is less than 100 feet regardless of whether the environment is urban or rural.
When you manually switch TX up to 5.8ghz, does the control signal become as reliable as the 2.4ghz frequency used to be?
Did the problems with 2.4ghz signal begin after you updated the firmware to *.**.0770?
