Please guys... It might be very important...
I have developed a theory that explains why and how the Mavics are dropping down from the skies... I would like to hear your thoughts and contributions, please...
I have read lots of flight data logs that were published by its unffortunate pilots, trying to find any points in order to clarify what had happened, there 2 or 3 details that all events have in common, but there is one that highlight my attention since the first reported case: the last system message is always "MAVIC HAS LANDED"
Normally, in any other case of crashing, the last message is "LOST CONNECTION"... Even in case of battery disconnection, the app and remote controller loose connection with aircraft and "LOST CONNECTION" is the last recorded message in the log, which is correct. But with the dropping down events this message is never recorded, instead the last one says that the aircraft has landed and that means the end of a normaal regular flight.
My theory: the system thinks that Mavic has landed, or in other words, Mavic is touching a surface, then, when the pilot commands to go down, the motors go to shutdown, as is designed to happen.
Now, lets think: how does Mavic know that she has landed? Using her barometer... The air pressure given by altitude is given to the system by her barometer, and the computer uses this data to maintain her altitude. So, saying this, how does the computer know that Mavic is touching the ground (landed)? Because the pilot moves the stick down and the Mavic altitude DOES NOT change, in other words, the data that computer receives from her barometer DOES NOT change...
And what happens after, when the pilot keeps the stick down after landind? Motors shutdonw!
Long story short, my theory is that the barometer freezes its data in middle flight, middle air, making the computer assume that Mavic has landed... Then the motors shutdown as expected with stick down command.
I really would like to hear from DJI about this theory...
Now, in order to try to avoid this serious issue... Could we avoid that if we leave the Landing Protection feature always ON? I believe that in this case the system would ask the pilot to confirm the landing...
I would like to move from theory to practise... I will try to simulate that, holding the Mavic from the top, with my hand, not allowing her to go down... Then I will command the stick down. She will think that has landed and shut down the engines after short seconds. If that experiment happens, I believe we prove the cause of the problem.
Please, sorry by the very long text... But I would like to hear your thoughts... And if any of you guys could make contacts and forward this message to DJI techs, it would be much appreciate.
Many thanks!
UPDATE:
- Thanks everybody for the comments... Lets keep it, please, and try to reach DJI techs... Another piece of advice I believe we can take from here:
NEVER DO FULL STICK DOWN DURING THE FLIGHT...
- Yes! Mavic does shutdown the motors "thinking" that has landed when hand catched... So, if a glitch happens in middle air and the sensors dont update the altitude the Mavic will assume that has landed and possibly shutdown the motors... That's my theory...
- Combination Stick Command in middle flight would be shown on logs... But I have never seen CSC in these events...
Many thanks!
UPDATE:
