Haven't seen a spotlight functionSorted! Nice POI. Next time give Spotlight a try. Lock it on to the subject, then fly past it to on side, gives a good effect. Not that POI isn’t good, it just gives another perspective
When you draw a green box around your subject, the default mode is Spotlight. So, draw your box, switch video record on, and fly towards & around the subject. The camera will remain locked on regardless of where you put the drone. Although it does have a tendency to loose lock if you fly directly over the top.Haven't seen a spotlight function
