You can find a complete list of compatible iPad models here:I am thinking of buying an iPad mini to use with my Mavic2.
Are there any models which will not work with it?
Both Wi-Fi only and cellular iPad Air/Mini/Pro models are compatible. Only cellular models have GPS. You do not have to activate the cell service in order to use the GPS. The DJI GO app currently only requires GPS on an Apple device when using the Follow Me feature or to reset the home point to your current location if you've moved elsewhere after taking off. If you're going to use a Wi-Fi only Apple device, you could attach a Bluetooth GPS receiver (like one of these) to add GPS later if needed.Is it worth having cellular as well as wifi?
Any other useful tips?
Best Tablets and Phones for DJI GO (Updated Daily)
Some of the 81% is likely using DJI GO. I wasn't always asking people to select their version of DJI GO when voting, so I don't have that data for votes that were placed before I started asking for the DJI GO version.But would like to know why poeple are disliking the iPhone X using DJI Go ?
Its intermittent at the moment: Mobile device gps signal weak It’s location can not be acquired on iOSIpad mini 2 have no issues - only thing I would love to have if I needed it was cellular service in case of a dynamic home point - I can link it to my phone with blue tooth to get wifi but not sure if dynamic home point will work - haven't tried it
The GPS location cannot be shared over a hotspot.I can link it to my phone with blue tooth to get wifi but not sure if dynamic home point will work
How the heck do you get it to fit into the controller arms???I also have a mini 5 with cellular. Smooth as silk, and it fits into the arms of the controller just fine.
Going to warn you here. the mini 2 is pretty much borderline on required horsepower to run Go 4. As soon as the weather warms up you are going to see issues with dropped video and lag. I would not recommend using a Mini 2. If you do be prepared to fly with no display when it gets warmer than 80 degrees.Ipad mini 2 have no issues - only thing I would love to have if I needed it was cellular service in case of a dynamic home point - I can link it to my phone with blue tooth to get wifi but not sure if dynamic home point will work - haven't tried it
That picture is really helpful. It made me realize that I needed to be more aggressive with pushing the edge of the iPad into the handle rubber grippers. Knowing that I can do this gives me a really nice alternative to when I forget to bring my newly-created mount, or don't have time to assemble it.This is what mine is mounted like but I do have an additional mount so that it is above the controllerView attachment 74748
I use the iPhone X with GO 4 and it works great. The display is fairly bright but not great in full sun like all displays. The downsides are it seems the controller arms block the Face ID from working and make it a little difficult to touch the little bar at the bottom to swipe up to exit an application. I am planning on getting a iPad mini as soon as I can justify the cost with my financial auditor (my wife).Just curious and checked the list. But would like to know why poeple are disliking the iPhone X using DJI Go ? :S
is it that bad ?
