Is there anything intrinsically different about fling over water, other than the obvious difficulties if you go down..?
Brilliant..where'd you get that..? Twitter..?!
(Sorry..couldn't resist...it's been a long night ...!)
.....that's you being humourous..?!
....or....do i actually have a brother in Wales ..?!
Sorry..it's now a hard night's day and sleep is close lol...and yes, sorry, i apologise far too often...
As long as you're flying high enough to keep the drone from getting wet, there is no difference. Just make sure you have sufficient battery power whenever flying over water so you don't experience an unplanned landing into the water.Is there anything intrinsically different about fling over water, other than the obvious difficulties if you go down..?
It might be that the concrete path will cause you more problems than the sea! We have seen several mishaps on this forum caused by magnetic 'drag' due to steel reinforcing in concrete. The effect is that when the Mavic sets itself up before takeoff, it does so in a magnetic environment not aligned with the Earth's natural mag' field. When it ascends, it suddenly discovers the misalignment and see's it as a control error, which can then have pretty bad consequences! If you use the concrete path as a landing strip, look at your compass [before take-off] down at the bottom left of Go4, and make sure that the arrow point is actually pointing the same way that the nose of the Mavic is ... If the alignment's not the same, that's an indication of magnetic drag, and you'd be best taking off somewhere else ...Umm..salt..irish sea..windy generally....rocky foreshore but good concrete path to launch from
In my opinion the actual flying, no. Planning for the flight, yes. I try to locate "bail out" locations to land where recovery is possible by ME. I don't tempt fate by getting real close to the water.Is there anything intrinsically different about fling over water, other than the obvious difficulties if you go down..?
